Dick_B
Nov 02, 2016Explorer
We have the older Winegard G2 that requires a separate 12V line to power the antenna until it finds the satellite then it can be disconnected and only the signal cable would remain.
I understand that the G2+ eliminates the power cable which is one less thing to connect and, if it works, would be a good thing.
I think it is a miracle when the little round dome finds a satellite and a crystal clear signal comes thru.
We also have a dome on top of the RV and use it whenever trees are not in the way. We have to switch signal cables to the receiver depending on what antenna is being used.
38,782 PostsLatest Activity: Aug 31, 2026
