Vacationer04's avatar
Vacationer04
Explorer II
Mar 22, 2017
putting oil in 8.1 after oil change
Is there a trick to putting oil back into an 8.1L after a change. No funnels or adaptors that I have found up to now fit the opening or the fill tube so that I can use the 5 Qt jugs. Anybody got a slick trick to do that? I am working with a '04 HR Vacationer.
  • Or, you can pour from the 5 quart, to a 1 quart, which may be easer to fill with. I always save the quarts for this purpose.
  • In those oddball places hoses are the best. Just be sure it is securely in place before you start pouring or you'll get oil everywhere!
  • SpeedCo..:) I know, not helpful..sorry....:B
    Seriously though, the above 'trick' works the best. I used to cut the top off a quart bottle and use that as the funnel. Piece of garden hose on the end of that and you're done. No muss, no fuss....Dennis
  • Make an extension tube out of plastic tubing and then attach it to a funnel outside of the hood. On my Monaco I can slip the 5 Qt container under the hood and tipping it sideways I can pour directly in to the oil fill opening.
