pappaoneExplorerJun 18, 2014PVC pipe has crackNoticed that PVC line between grey tank and drain valve has hair line crack in it. Is the a way to fix it without having to replace the pipe? Maybe with JD Weld for PVC & Plastic?? Thank youShow More
FiverwheelExplorerJun 18, 2014Make a patch from a piece of ABS pipe and glue it on with ABS cement...good as new!
Related Contentmaking a pvc sewer pipePVC Vent Pipe Mod QuestionPVC roof failurePVC Pipe Solvent/Cement, How do you Prolong in storage ?Do holding tank weathervanes glue to standard PVC pipe?
