timmac's avatar
timmac
Q-PADS for your Gas Motorhome Doghouse, Works Great.
I bought 2 packs of these Q-Pads
Restores vehicles to OEM specifications to provide original quiet ride. Self-adhering, sound deadening panels designed to reduce noise levels in cars and trucks.
Wow what a difference it made, cut down the engine and fan noise by half, my noise level before was good but now is great, 08 Bounder Ford chassis.
Just make sure if your going to use it install pads on entire doghouse and as far forward and on front fire wall area if you can.
Cost me $95.00 for 2 packs, total 12 pieces 12x12in.
http://www.evercoat.com/productDetail.aspx?pID=50
:C
  • timmac,
    First off, I've never heard of them. You don't by any chance have any pics of the install do you? Is it foam, a wool product, plastic with foam on it? What? The link you sent is only an ad for it but, there's no pictures or application demos etc.
    Scott
  • Does it have a reflective surface? If not, doghouse cover may get really hot. Had this problem on our Class C with some material that was supposed to do the same thing.
  • Sounds like a great upgrade. How much did you need to clean the surface to make them stick?
