Now that the subject of VF is put to bed lets see if we can get back to the original subject of ridding ourselves of our grey and black waste. The black of course is the main problem. That has to be pumped out and removed from the area by a pumpout service or by you breaking camp and visiting one of the local places that allows dumping. My favorite subject tho is the disposal of the grey water. When the pumper shows up to dump you by all means do the grey as well. But for those times in between when the black is not ready take your special garden hose that is labeled for grey water only and hook it up to your black and grey water cap at the place provided to screw a hose to. Place the hose in the bushes in a snake/gopher hole or in the nearby creek/drainage ditch and be sure you know the grey water drain valve from the black water drain valve. (They are both black in color) Anyway open the grey water drain valve and drain the grey out.
Upon reading this I am sure there are those that are going to holler illegal,unclean and whatever else they can think of regarding this action. It is not illegal on BLM land in the quartzsite area. Let the argument begin.
