RJL's avatar
RJL
question about power steps
Am having intermittent problems with our steps on the below listed rig. Sometimes they work, sometimes they don't. Very common, I know. I crawled under the rig tonight and unplugged the connection between the batteries and the steps. Banged it together a bit, didnt see any corrosion or foreign material in the plug ends. Plugged it back in and eureka! It works. Is there a spray I can hit the plug with to keep the plugs talking to one another? Can't help but think the plug is the culprit, at least in my case.
  • When I had the same problem with my steps, it turned out to be the magnetic door switch.
  • well if your battery is low,they,ll do funny things, I,d take the connections apart spray with a contact cleaner, remove the ground wire if theres one there . and hope it works. don,t know alot about them. but keep mine lubed .
