Gundog
Mar 18, 2019Explorer II
Question about solar panels?
My 05 Fleetwood Expedition has 2 solar panels one is a very small panel on the housing of one of the AC units I believe that one was factory installed. The second solar panel is much larger approximately 3' x 4'. When I was changing out my battery bank there is a set of leads about #14 wire. The positive lead has a glass fuse holder inside was a 500 mA fuse that does not ohm out. .500 mA is really small it then attaches to a small panel inside the battery compartment I will post a picture of the battery bank you can see this small panel in the picture. Is this little panel for the small solar panel? The small fuse size is either wrong or maybe a control wire or for the very small panel on the AC unit.
I am guessing my large solar panel must be connected to the Inverter/Charger? I have 2 large sets of cables going from the battery bank to the inverter charger area,one set is 3/0 & the other set is 2/0. Can anyone explain how the large solar unit is ran and what the small panel in the battery compartment is for?
Thanks Mike
Small panel is located between battery 1 and battery 2.
Thanks Mike
