dougrainer
Oct 26, 2016Nomad
If you are using the wall panel as a way of watching your battery level, that is NOT the way to do it if you are connected to shore power. That panel will always show the voltage range of the Power Converter, regardless of the batteries. You can REMOVE the batteries and that panel will still show 12 volts when connected to shore power or the Engine is ON. Doug
