wtfjr's avatar
wtfjr
Question on fuel consumed by our generator AND ??
While camping at Sebastian Inlet we could always run our generator during the day to help keep the coach cooler & we are curious how much gas it will burn per hour or per eight hours, or whatever time unit ?
Our generator is an Onan 7.0 KW
Our front a/c unit is a high profile w/heat pump
Our rear a/c unit is a standard high profile high efficiency unit
Our unit is about 32' long.
And, can we run the generator while plugged into the available shore power plug in pole ? Or should we unplug our unit from the pole before starting our generator ?
Thanks for your comments & or suggestions
Bill & Marilyn !!
  • Ha, just looked at your profile... is this one a keeper?:B
  • We looked & found no info on fuel consumption for the generator ?
    Any other suggestions ?
    Thanks !
  • It may be different on each coach but on my coach when I am plugged in to shore power and start the generator, the generator takes preference. In other words, I am not using power from both sources but ONLY the generator until I shut down the generator and then the shore power takes over again. I do not have to disconnect the power cord because the transfer switch takes care of switching power as needed.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    YOu owner's manual should have listed the fuel consumption at both no-load and half load.. For A/C on yoru genny, half load is about right.
