lanerd
Jul 19, 2015Explorer II
Two Hands wrote:
I have the coach described below. The dealer told me to dump the air bags then use the automatic levelers. Freightliner told me not to dump the air, the air would automatically dump when I started the leveling process. I don't hear any air being released when I turn on the levelers. I cannot find anything about leveling with air bags in the Fleetwood Owner's Manual nor can I find anything in the Freightliner manual. You probably don't have air leveling...just HWH hydraulic jacks. There are different control panels for the HWH jacks and their operation can be different. Dumping suspension air should be done whether by the HWH control panel or by a separate switch. Then you would level the coach with the HWH jacks.
The Maytag refrigerator icemaker doesn't work. The Maytag tech said it is not getting any water. Fleetwood told us the connection under the bathroom sink is probably not turned on. Neither the tech nor I could find the connection. Most ice maker water connection is located in the outside inspection/maint panel. Typically it is just on the other side of the wall where the fridge is located. There will be a small valve with a clear/white 1/4" tubing going up to the back of the fridge.
Can anyone offer any advice or point out someplace to look in an owner's manual. [COLOR=]You might have a separate brochure for the fridge and maybe something in your owner's manual.
38,708 PostsLatest Activity: Mar 05, 2025
