tatest
Aug 23, 2015Explorer II
Almost all C's will have a long overhang, it is needed to get weight distribution where it needs to be for a dually with a largely empty box. Shorter C's are shorter wheelbase, an advantage in tight places. The exception are a few models built on single rear wheel chassis, which need to put the axle close to therear to get close to 50-50 weight distribution rather than up to 65% on the rear.
If you will sleep in the overhead bed, you can find rear bath floorplans as short as 21 feet, Usually on Chevy 3500 or Ford E-350, some ex-rentals on F-250, and Winnebago even built one using the front-drive VW T-4 cab (Vista/Sunstar up to 2004).
Dedicated bed on the floor, 24-27 feet, either in a rear corner alongside tiny bath, or crosswise in rear, open one side and one end, with a mid bath. Jayco, Winnebago, Coachmen, Forest River, Gulfstream, Fleetwood, FourWinds (3 brands) all did the corner bed with a 24 model number, I've seen the other one only from Fleetwood, 26-something actuall 27+ feet long.
I would rather not have slides, the 12 year old C I've been using for the past 10 years has two of them that have been trouble free, but I find them an inconvenience relative to the value to me of the little bit of added space, now that I am alone and want to use the RV differently, e.g. always on the go rather than setting up a house for 2-6 people for a week or longer. Working now on downsizing which could be a van conversion under 22 feet, or a towable under 18 feet.
An old Vista or Sunstar might work well for you, since they are were a foot narrower than conventional Cs, as well as having short overhang.
38,782 PostsLatest Activity: Sep 10, 2026
