RBabb's avatar
RBabb
questions for winnebago owners
I have a 2000 winnebego ultimate advantage 36c and have some items I can't figure out.
1. Diagram showing labels for fuses and relays in main box up front.
2. There's a small momentary black rocker switch in upper right corner of Guages. What does that do?
3. There's a large black rocker switch by the power window buttons. When you flip it a green light comes on. What does it control?
4. The spot light on top, anyone know how to operate it?
5. My solar panel on top is cracked, anyone know the model, brand, or any replacement info?
6. May dash radio has no power on yellow constant voltage wire. Anyone know where this feeds from?
Any help is appreciated
  • I use to own an identical coach a year ago.
    The momentary switch is your battery boost that connects both sets of batteries in the event the chassis batteries have to low of voltage for starting the coach.
    The switch with the green light is your mirror heat.
    I did not have the spotlight so I can't help you there.
    If you go to www.irv2.com and go to the "Winnebago Industries" forum you can get the wiring diagrams along with other vital information for your motorhome. You can also ask about the solar panel.
    Paul
  • On mine the momentary switch is for starting when coach battery is dead or low, it allows house batteries to start it. The one with the green light on mine is heated mirrors. Mine is 06 Sightseer.
