goufgators's avatar
goufgators
Quetion re: pad for tires on concrete
I began preparing a pad out of pressure treated lumber for our MH tires to sit on rather than sitting directly on the concrete pad. My thought was to use PT lumber to make it weather (last) longer. But, am now wondering if it is wise to make the pads out of pressure treated lumber. Is there a chance chemicals in the PT wood might leach into and damage the tires? Any one with thoughts about this?
If this is not wise, what would you make the pats out of that would stand up to rainy weather? Thanks! / Larry
  • Michelin Tire on there website for "Quality Tire Care" recommends that the tires should not be parked on concrete. You can read about it and there explanation why on there website! They recommend if your concrete pad is dry you can use cardboard, if not rubber would work fine like one of those mud flaps you see along a road. I use untreated wood on mine 2" X 10" 2' in length. Sorry, Brett and I were posting nearly at the same time and he got on before me!
  • From Michelin's RV Tire Guide: https://www.michelinb2b.com/wps/b2bcontent/PDF/RV_Tires_Brochure.pdf
    LONG TERM STORAGE OF RV TIRES
    Unless the RV owner is a full-time RV-er, the vehicle
    probably spends some time in long-term storage. But
    what the RV owner probably didn’t know is that rubber
    tires age when not being used. So, if the owner must store
    the RV, a cool, dry, sealed garage is the best bet. Also, some
    storage surfaces can cause tires to age faster. That’s why
    Michelin recommends placing a barrier (cardboard,
    plastic or plywood) between the tire and the storage
    surface.
    Here are some other steps the RV owner can take to
    help reduce the aging effects from long-term storage:
    1) Thoroughly clean tires with soap and water before
    placing into storage.
    2) Cover tires to block direct sunlight and ultraviolet
    rays.
    3) Store out of a high ozone area.
    Note: When a vehicle is stored, tires should be inflated
    to the inflation pressure indicated on the sidewall.
    Before removing the vehicle from long-term storage,
    thoroughly inspect each tire – this includes sidewalls,
    tread area, and pressure. If the tires have lost pressure, be
    sure to inflate them to the correct pressure before driving.
  • You are better having them sit on the concrete unless we are talking long-term storage at which point the weight should be off them completely. I know a little something about tire compounds...
  • Stop trying to over think/engineer this. Park them on Concrete
  • Park them on the concrete....and if they are exposed to lots of sun - cover them.
  • Effy's avatar
    Effy
    Explorer II
    What's wrong with the tires sitting on concrete?
