carringb
Nov 23, 2019Explorer
FWIW - here is Ford's official policy for long-term storage for the E-series:
• Change the engine oil and filter prior to storage because used engine oil contains contaminates which may cause engine damage.
• Start the engine every 15 days for a minimum of 15 minutes. Run at fast idle with the climate controls set to defrost until the engine reaches normal operating temperature.
• With your foot on the brake, shift through all the gears while the engine is running.
• We recommend that you change the engine oil before you use your vehicle again.
That said... I know many folks with V10s that do nothing special for the engine. The generator is the neediest component on the RV, and probably does need special attention to ensure it starts back up.
