23hotrodr
Sep 30, 2021Explorer
I have the same issue at times. I will bet you have balancing beads in your tires and dust from them gets into the valve cores and holds them open. You need to give them a shot of new air before trying to check pressure to clear out the debris and let the cores to close. You should not rely on valve stem caps to hold pressure in your tires. There are valve stems with screens that are made to keep particles out of the valve cores that you can have installed to fix the problem. Or, you can just give them a shot of air before checking pressure to make them work properly. Good luck-- Mick
38,782 PostsLatest Activity: Sep 10, 2026
