dodge_guy
Sep 30, 2021Explorer II
Pangaea Ron wrote:dodge guy wrote:
I’m thinking you are over the valve cores max pressure. And why 105? Have you weighed the MH? I’m certain you don’t need to run over 80 psi. I run 75 per Michelin’s pressure/weight chart. My rear axle I run at 95 per the chart.
105 is the recommended pressure. I bought a new compressor to achieve that.
I doubt your 08 is heavier than mine. Unless you had it weighed 105 is too high.
38,782 PostsLatest Activity: Sep 10, 2026
