down_home
Sep 30, 2021Explorer II
We had the left front wheel assy valve core come loose in Shawnee, Oklahoma. Chased down a Sap On Dealer to buy vale core tool to tighten it up.
I don't remember if the G670 tires were well balanced or not.
Cores that are inferior(cheap)may be the problem, as it was with the Chinese valve stems that caused the failure of all four tires on ourF150.
Other than that, out-of-balance sounds reasonable as a cause, without any real experience on the subject.
In my 73 years that one experience is the only one.
When we replaced the front or steer axle tires with Michelin "steer axle" tires with decoupling groves on the edge and center groove. It took 1/4 ounce of weight on one wheel and 0 as in none, on the other wheel.This on 285x22.5 tires and wheels. Outstanding! And the ride was smooth with more flexible sidewalls and in balance.
I have no idea how to identify a quality valve core but would question where you buy the next ones.
*Bad spec valve cores, the more likely or possibly metal valve stems, think is the problem. Everyone, that is the Tire sales places tend to buy all the same, cheap and the same brand.
If this is the case the problem will emerge over some time and the Dealers who sold and installed them will face big problems in reputation, and claims possibly including injury and death from wrecks.
This is one reason I check the tires with a laser pointed temp gun every stop, and the tire pressures checked and adjusted before we headed out. Checking tire pressure was a challenge for me, to get accurate readings so It was done by mgr where we stored it and at shops along the way if thought it needed.
38,782 PostsLatest Activity: Sep 10, 2026
