wallynm
Sep 30, 2021Explorer
We did a bead balance one time and had this problem. Replacing the valve stems will not solve anything IMHO. WE just lived with it. But relied on the TPMS to tell us when it was time put air in the tires.
Pangaea Ron wrote:
My front radial tires are Toyo 245/75R 22.5.
When checking air pressure (105 pounds), I occasionally have the cores fail which allows air to escape dramatically, and I need to scramble to get the cap back on the valve stem on or replace the cores. This time I took it to Les Schwab Tires for them to check air pressures and to replace the valve cores. Both front tire valve cores had failed.
This seems to happen about every 6 months. Does anyone else have this issue. They said that it is common with high pressure tires?
38,782 PostsLatest Activity: Sep 10, 2026
