LowS's avatar
LowS
Radio/back up camera not working
Hello. I hope someone can shed some light on what May have cause ikr is causing my radio/back up camera to go out. I started my 2013 coachmen concord and everything was working good. I heard a click and I turned it off. I stared it again and after a couple minutes I heard a click, this I realized the radio had clicked off. I shut the motor off again and started it back and the radio didn’t power up. I put it in reverse and the back up camera will not come on. Any suggestions out there?
  • How long since the coach was started, possible rodent issue chewing on wiring?
  • If the radio and backup camera are separate devices, then it sounds like a blown fuse. If the backup camera uses the radio display, then it could still be a blown fuse, or maybe some component in the radio failed.
    Of course, fuses usually don't blow for no reason, so you may still have a wiring problem (like a pinched wire that finally wore through the insulation) or failure in the radio that made the fuse blow.
