wildmanbaker
Nov 12, 2018Explorer
I have seen some inverters that pull 4 amps at idle, no output load. That being said, 4, 6 volt batteries should last at least overnight. Have you checked the battery connections and the level in the batteries. A swelling I the cable usually means there is corrosion under the insulation.
38,763 PostsLatest Activity: Dec 13, 2025
