MrWizard
Nov 12, 2018Moderator
4GC batteries
You should have around 400+ ampHrs total until dead, I don't think you used that much, but I'm not there
You should have around 200+ ampHrs useable, for doing 50% load use cycles
Heater 7 to 10 amps when cycling say 50% run time, aka 30 minutes per hour
45 amp hrs 6pm to 3am
How much power does the stereo system use?
The tv?
Are your batteries charging when you drive? The battery control center may not be operating correctly
Biggie do you use the : heater: in your cpap, that's a big power user
Fairly new batteries?
They must be fully charged (could be an all day generator run) best done on shore power, then load tested and sg tested specific gravity with good hydrometer
They may have been neglected by the previous owner
The tv?
38,763 PostsLatest Activity: Dec 05, 2025
