theoldwizard1
Nov 12, 2018Explorer II
First, let me say, you can throw a lot of money at this issue especially if you want someone else to do all of the work. The diagnosis is not that hard, so it is time to learn a bit about 12VDC electric power.
You need 2 tools, and old fashioned non-LED 12V test light and a multi-meter, preferably one with a built in "amp clamp" like this one.
A good quality pure sine wave inverter easy between 80-90% efficient.
LESSON #1 - Watts is watts, whether it is AC or DC, 120V or 12V (well, close enough anyway) and voltage time current equals watts or V x I = W (I don't know why they use I for current). If your CPAP machine draws 1A @ 120VAC (120W) it is going to need about 10A @ 12VDC (120W). Then you have to add the loss of the inverter so you need an extra 20% or 12A.
Probably, but it does depend on how good a job your charger does topping off the batteries.
LESSON #2 - Monitor your battery voltage. There are many different volt meters you can mount inside the coach at a convenient location.
Concur on both !
Gundog wrote:
Do the inverters draw a lot of power if they don't have a large load on them?
Gundog wrote:
Had I run the generator before going to bed we would have probably been OK but it seems it should have lasted longer than it did.
Gundog wrote:
My battery bank for the house is 4 - 6 volt golf cart type batteries.
camperdave wrote:
With 4 6 volt batteries you should have no issues getting through the night even with the heater. Checking the dates and condition of the batteries would be step one.
Trackrig wrote:
Also - check your battery water level and clean your battery cables.
Concur on both !
38,763 PostsLatest Activity: Dec 05, 2025
