rgatijnet1
Nov 12, 2018Explorer III
When you run the generator before you go to bed, be sure that the charger portion of your inverter is turned on. I also usually turn off the charger prior to shutting down the generator. Not sure if the inverter draws more power with the charger left on without the generator running or connected to shore power.
38,763 PostsLatest Activity: Dec 05, 2025
