MrWizard
Nov 12, 2018Moderator
Ok 2Oldman then ..say 'Fluid' :)
to the OP
is that a DC amps clamp on meter, you need to measure the inverter load from the battery
also check your fridge and water heater.. set for LP only, NOT in automatic mode
inverter is whole RV, you don't want the fridge switching to 120vac inverter power
to the OP
38,763 PostsLatest Activity: Dec 05, 2025
