time2roll
Nov 13, 2018Nomad
Yes I also would expect 4x GC2 to run the furnace, a few led lights and the tv for the evening and then furnace/CPAP through the night.
Yes test the batteries... probably with a hydrometer first. Few people know how to load test them so most just fail.
The bigger unknown is what else could have been running off the inverter. Possibly the fridge (absorption or compressor?) and possibly the water heater. Most large inverters will idle at 3 amps... then it is the load you connect.
You need a way to monitor battery voltage as a minimum. Possibly consider a full battery monitor.
The 12 Volt Side of Life
38,763 PostsLatest Activity: Dec 05, 2025
