time2roll
Nov 14, 2018Nomad
Gundog wrote:You should see charging at 14+ volts. As a test let them charge 48 hours and then fully disconnect and separate the batteries. Let them rest 48+ hours and recheck the voltage. Should hold 6.35 volts.
After the batteries went to 9 volts and I ran the generator for 3 hours they read 12.6 volts. I don't think they are gone but they are definitely not great. I have been charging them for 2 days now after adding the water so I will just have to see. I haven't had time to mess with it again. If the batteries are junk come spring I will replace them.
Even if they hold voltage and are serviceable they may have significant capacity loss due to low electrolyte.
38,763 PostsLatest Activity: Dec 05, 2025
