- lillyputzExplorer IIUpdate :
Camping World is going to exchange my 7725-LM, for one of equal value.
I'm a happy camper.
Lillyputz - Finally_TimeExplorerI'm another one with no problems using the RM 7725 in my motor home. I've used it for 8,000 miles in unfamiliar terrain. No problems with glare or difficulty seeing it in bright light. I do have problems seeing the motorhomes instruments in daylight so I use the RM as a speedometer. Last big trip I caravanned with some friends who were using a smart phone app. Both sent us on the same routes. I always used a Garmin in my car. The RM takes information differently and there was a learning curve. Now that I am used to it, I like it better than the Garmin.
- lillyputzExplorer III purchased the Rand McNally RVND 7725-LM, because of the RV features, advertized by Camping World and endorsed by Good Sam.
The problem with this unit is, it routes me on a longer route as compared to the trip routing features on the Good Sam site and my old Tom Tom as much as 500 miles. It gives the same route on the car setting.
I've talked to two differant tects at Rand McNally. They know this is a problem, but said there is nothing they can do to re-program, that's how it's designed.
One tect told me to put in shorter trips, to get to my destination, that way, the GPS would keep me on the same route as my Tom Tom or Good Sam routing.
Comparing the Good Sam trip routing and my Tom Tom, on any route, only varys by a couple of miles.
I have requested my money back from Rand McNally and Camping World. They refuse, saying, I've had it more than 30 days.
What a joke, after all, Good Sam endorses this gps.
Lillyputz - MRUSAExplorerI am amazed by the negative comments. I have had a RM 7710 for over a year and have driven over 12,000 miles with it, and I have found it to be excellent. I've had no major routing issues, and the only mechanical issue was a loose power connector, which is a problem on some 7710's but has been changed on the later models.
I find it particlarly easy to find RV type places such as rest areas, Flying J's, and Walmarts. The campground database is far better than on the Garmin that I used before. I like it so much that I am in the process of trading it up for a 7720.
I met the design engineer and he is an RVer who knows waht we want and need in a nav unit. - nomad297ExplorerI have had the same problems as Effy with my 5510. Every time I contacted Rand McNally about it I was told that the next software update would fix it. Half a dozen software updates later, it freezes up more than it ever did. I am sick of my 5510 and am shopping around for a better unit.
Bruce - EffyExplorer IIHated every second I had to use either of my RVND's. That's right I had 2. THe first one plain stopped working, the second one still freezes up. When it's not frozen, it misses CG's (what's the point of an RV GPS that can't find a popular CG) misses gas stations, can't find my local rv dealer and that's what I know of. Now I LOVE my new Garmin dezl 760lmt. Does what it should and performs flawlessly. More intuitive, easier to read, easier to update and is just plain better.
- Bea_PAExplorerThx for the review. I'll stick with my Garmin 2555 for now, in the 20,000 miles we have used it, most mistakes have been minor and more omission than anything. I still route by map and keep it handy. Maybe someday someone will give us a really good RV GPS.
- Fargo44ExplorerI said I would follow up after taking with Rand Mc Technical support. I did and here it is.
I talked at length with two different folks on the tech staff at Rnd Mc -- both were courteous and fairly knowledgeable about the RVND 7725 LM but neither had much of a clue as to what the driver of a 12 ton, 55-ft long vehicle might want to have or need on the road. Pity.
I learned a few things about the options and got a few suggestions from them as to how to fine tune it to my needs/desires.
Yesterday, I drove around the I-275 beltway with the unit in my Jeep but on "RV" mode. I tried all their suggestions and the bottom line is minimal improvement and I have decided it is a "no go". I've given the unit more than a fair test and I'm sending it back for a refund as I am within the 30-day period.
Bottom-line is for this kind of money you should NOT have have to work so hard for such spotty or mediocre roadway guidance.
In talking to the techs I started to get an inkling of the basic problem with the RVND 7725-LM -- it was designed by a committee! For example, you will notice if you are on "RV" mode (and I presume that is why most of us would buy it right?) that the unit displays ALL the animal hospitals, veterinary clinics and dog parks! These icons are hard programmed into the "RV" mode and the only way you can shut them off is to go to "Car" mode. But do are not driving automobiles are we?
Why are these animal care icons not optional? Because it seems a user group panel supposedly RV'ers (I guess most of whom had pets?) decided that this was information that all RV'ers needed without question.
But, I don't need it. Furthermore, the 25 (or more) "pet POI's" that pop up and take up a good percentage of the screen when I'm near the Cincinnati metro area are not appreciated. Doubly so when no matter what I do the RVND 7725-LM (regardless of what scale or which POI settings or filters I pick) it will NOT reliably display icons/locations for all gas stations, truck stops or diesel fuel outlets -- something I really need.
When I mentioned the fact that the unit warned of small insignificant curves and then totally missed some serious ones the tech thought I should be grateful for the warnings I got. I really did not agree.
The RVND 7725 LM (and other related versions) are marginal GPS devices in my opinion and not worth the considerably greater amount of money charged. Yes it could work for some and maybe I am too picky about the unreliability and questionable layout/options but they are deal breakers for me.
I've read and watched a lot of videos on the Garmin RV 760LMT and it seems to address some of my issues with the Rand Mc unit but it is hard to evaluate properly from canned videos and it has its share of negative comments out there too. - ltmExplorerditto on the rvnd7725 it is only correct 50% of the time it is not worth having
- down_homeExplorer IIOur Rand McNally has pulled several Garmins such as telling us to do a Uie and five miles back down the road turn right and lead us down goat paths, and country roads in a loop a mile down the road we were on in the first place. Relatives with their new Garmin last week. It directed us to turn right instead of left and took us 10 miles or son on that route and then told us to turn left and made a giant uie back to the same road and 20 miles back the way we should have gone. Let us through narrow road hollows in a big uie to the road we should have turned on in the first place a second time. And there were so many others, if it were mine, I would have thrown it out the window.
38,774 PostsLatest Activity: Mar 01, 2019
