Off-Road_Racer_
Apr 15, 2014Explorer
tenbear wrote:Harvey51 wrote:I am not able to run the water pump and the furnace will not run. I do have interior lights,
Lights work means 12 V system is working. That rules out batteries and converter problems. It just leaves fuses, doesn't it? Best to use a meter, ground the black lead and use the red to see if there is Voltage on the outgoing side of each fuse.
Do your lights dim when you try to run the water pump or the furnace?
No the lights do not dim. We currently wired the water pump directly to a battery so we can have water.
We have not gotten the furnace to work.
38,705 PostsLatest Activity: Jan 24, 2025
