HuckleCat wrote:
Hello Jacob!
I have a 1975 REVCON I am currently working on. My tires are the same as yours. Luckily mine are only a couple of years old and in good condition. I am researching how to get a more common size that will work with the bolt pattern etc. Will let you know. I want to have the tires in a size in case of something happening on the road.
Check out my REVCON here. It is a work in progress.
Our 1975 REVCON album - work in progress
HuckleCat wrote:
OH! There are not many REVCONs around. Thats the reason I like mine.
There are parts that may be difficult to find. Rear shocks if you ever need them are not available. I had front shocks, and most of the front end wear items on mine replaced. Those are available as the Revcon used the Toronado drive train / front end pretty much as supplied from the GM factory.
Hi Huck! Thanks for your reply. I was able to find tires... I found some 9.5-16.5 transforces for the two front wheels and some 12-16.5 STA tires for the two rear wheels because one of the previous owners changed the two rear wheels (1 inch wider than the front). Thankfully I don't have any rear end work needed right now, but what are our options if something takes a **** on us?
