Craig___Karen
Oct 23, 2015Explorer
We have hot water! I did place the electric thermo in the space below the propane TSTAT and ECO on the front of the unit. Took some patience to peel back an area of the outer skin so that the thermostat could be mounted directly on the tank. The installation of the anode was also tricky due to the propane valve assembly being in the way. In all, it took me about 2 hours, including draining the tank twice due to forgetting to tape one fitting and solving a leak. On for just under an hour and the water is hot but the thermostat will probably need to be adjusted up. We are on very cold well water in camp here. I highly recommend the Campco 11673 Hybrid Electric water heater conversion.
Thanks again for all the great advice and support.
38,705 PostsLatest Activity: Jan 14, 2025
