rvrepairnut
Jun 23, 2012Explorer
LonestarV wrote:96Bounder30E wrote:LonestarV wrote:
Thanks for the replies all!
Scott - so the blower won't work at all in that scenario? If that's the case, maybe that's the problem after all...
The blower will work irregardless if the refrigerant has leaked out or not.....what won't work if the refrigerant has leaked out is the compressor clutch......even then you can bypass the A/C pressure switch to manually turn the compressor on.....
Like I asked above...........does the blower work?
Not at the moment. Only thing that happens when you move the fan switch is the relays click. No air blows out of the dash, nothing.
Best thing to do is find out why the fans are not blowing and AC lite not coming on before worrying about the actual AC system.
38,763 PostsLatest Activity: Mar 21, 2016
