Ok, My ongoing problem may not be the transmission. I am learning more as I search the internet.
1. The temp sensor inside the transmission is to control cold (0 degrees C or below) shifting patterns. So that is probably not a problem.
2. Engine coolant temp sensor is what is used to change voltage to the PCM (power train control module)
3. The Tow/Haul light will blink on/off to indicate a transmission fault. I did not noticed it blinking during our trip. However, I didn't know to look at it.
4. The transmission works correctly, the engine runs ok.
Just have this weird sound that occurs after pulling a long hill when the transmission has shifted down. Then we start getting a Shhhhh noise that increases with throttle pressure and stops when coasting. After stopping, the noise goes away.
So at this time I am flummoxed. No clue to what is causing my issue and not enough info to help diagnose a problem.
Thanks for your inputs.
Rolin
