GBaxter
Jun 11, 2014Explorer
This sounds like a DC issue. I would guess that when the key is turned ON the chassis/house battery solenoid closes which is causing the DC voltage to drop which in turn dims the DC lights. The AC voltage probably drops because the inverter/charger is ramping up the charge rate when the chassis battery is connected which is a load on the AC side. 3 volts is nothing to worry about on the AC side and may be normal if there is a load like the charger applied.
I would check the Magnum panel and see what the DC amp reading is and if it goes up with the key on. Also check the DC voltage on the panel and see what it does.
Gary
Gary
38,714 PostsLatest Activity: Apr 10, 2025
