brianseay1ExplorerAug 23, 202122.5 wheelsthis may be a stupid question but i'm gonna ask it anyway. Can you run a steel wheel on the rear inside and a Alcoa aluminum wheel on the outside without any issues. I'm thinking it should be no issue...Show More
HikerdogsExplorerAug 28, 2021You might need new longer studs on the rear drums or rotors. Aluminum wheels are much thicker than steel ones.
Related Content22.5 Wheel size ?????Wheel bearing repackingMotorhomes with 19.5 vs 22.5 tires22.5 tires $$$$ ?5th Wheel took out rear window
