wbrowningExplorerApr 25, 201699 Chieftain 5.9 Cummins wont stay runingEngine was running with reduced power so I changed filters it seemed to not be picking up fuel so I changed lift pump same thing if I get system primed it will run for a few minutes then die if you p...Show More
wbrowningExplorerApr 25, 2016I will look at the fuel drain valve on the side of filter housing on side of engine.
Related ContentCummins Hit with 1.7Billion for Emissions Defeat Devices6.7L Cummins VS 6.7L Cummins HORam Cummins/Aisin Failures86' Chieftain Acquisition34 ft 89 winnebago chieftain
