MfreyderExplorerMar 22, 2014Bad VibrationsBought a Four Winds Chateau Sport a month ago. Coming home we had a bad vibration that turned out to be a bad tire. RV had new tires on the front, 2011 tires on the back. Replaced all four tires on...Show More
rongtamwExplorerApr 04, 2014On some Fords they use a compression pin as a guide for the rims. Is it possible that the pin was not aligned when the tires were changed?
Related ContentJust Bad Luck?Great to scary badvibrationslight vibration on accelerationVibration issue
