Okay, no corrosion anywhere. All connections look good. I cleaned off a little road dust. Ground looks intact. Fuse looks okay.
So, then I plugged the RV back in, turned the charger on and measured the voltage across the cables that connect to the batteries from positive to negative without the battery in place. I am getting 13.8v across the circuit. So, it appears that the charger is trying to charge the batteries, but they won't take the charge.
I have a Freightliner dealer/service 30 miles from home. I am taking the chassis batteries over there to have them load test them. I suspect I'll be buying new ones.
Thanks,
Wayne
