DaCarmack
Sep 30, 2023Explorer
I ran into the same problem as you are. I have a coachman Concord 275DS. There's only enough room for one battery without extensive modifications that do not want to do. If You have the measurements of your battery box You can look at AGM's in the solar field. I put a battery called a mighty Max It was 135 amp hours that worked really well. Then I came into possession of a battery called NPP that is 155 amp hours. This was the biggest battery high-wise I could fit in my box that's in my step. The only modification I had to do was to extend the threaded rods for the safety strap. Now if I'm at a rest stop I don't have to worry about power. we can turn on this light or that light, we can be wasteful is the best way to put it. You do need to make sure that your converter can charge it at the right voltage which I believe is 14.6v, the one I have is just at the minimum and I haven't had any problems
38,708 PostsLatest Activity: Mar 05, 2025
