Re: Brass makeovers??
If you mean by painting, don't do it, it will eventually flake off.
I just had all the brass shower stuff replaced with brushed nickel. Had the local glass shop come and measure the existing enclosure and make one in nickel. They assemble on site so that it is custom fitted so you can change some dimensions such as make it taller or shorter and change the way the door swings. You can also add towel bars in different locations
No RepliesBe the first to reply
