- Ron3rdExplorer III
jmccen58 wrote:
In regards to "extend-a-stay" propane set-ups, are Marshall brass products worth the extra $$$ ?
The only one around, as far a I know, was Marshall when I bought my Extend A Flow 11 years ago. The Camco stuff is usually OK. - bukhrnNomad
jmccen58 wrote:
Cheaper here,http://www.rvpartsoutlet.com/product_info.php?cPath=820_111&products_id=12276
Sooo... any input on this one ?Camco Extend-A-Stay
I don't see much if any difference between the Marshall & the Camco, both do exactly the same thing. - jmccen58ExplorerSooo... any input on this one ?Camco Extend-A-Stay
- Clay_LExplorer
wa8yxm wrote:
You do not have a choice, Marshall Brass dropped the line, Mr. Heater picked it up.
Actually Mr Heater was concurrent with Marshal and when Marshal apparently stopped making them for a while Sturgi stated making them.
It appears that Marshal is making them again.
I bought my Mr Heater Stay a While back in 2003 and Marshal was selling the Extend a Stay at the time. - gotsmartExplorer
- Dutch_12078Explorer III
path1 wrote:
I would of put in one of these "deluxe" models if I'd would of known about them at the time. The "deluxe" model covers about any issue you might have compared to the "regular" one. I don't exactly remember why deluxe is better but it is. Top hole you can run BBQ and bottom hole you can run RV off portable tank. Some people also install a ball cock so propane doesn't spit on you if removing hose under pressure. Other places also have them, but doing it again I would get "deluxe".
http://www.campingworld.com/shopping/item/stay-a-while-deluxe/30340
The only difference between the Extend-A-Stay standard kit and the deluxe kit was the inclusion of the 12' BBQ hose in the deluxe. The hose is readily available as an add on.
www.campingworld.com/shopping/item/12-propane-hose-assembly-with-swivel-ends/24038 - jmccen58Explorer
Marshall Gas Controls 536-00 Extend-A-Stay Standard Tap Kit - wa8yxmExplorer III
You do not have a choice, Marshall Brass dropped the line, Mr. Heater picked it up. - path1Explorer
Thanks for the link....But look at the difference in price from this oneCamco Extend-A-Flow. I know what some will be saying "Why worry about $30 if you own a MH?" Answer is "Thats how I was able to have a MH, by not wasting $$$"
I'm just concerned about proper lp flow rate from the "cheaper" option
These are installed before propane regular, any type of orifice and you'll have flow and lots of it no matter which one you buy. - jmccen58Explorer
About RV Newbies
