sluper
Aug 15, 2015Explorer
The issue with the Dodge 3500, 5.9 began with the 24 valve engines. Problem being the pump that feeds to primary injection pump. These lift pumps lose the pressure to the primary causing problems (galling) and then failure. Repair is quite expensive as is all work on our diesel engines. The FASS pump is probably the best recommendation to solve the fuel feed problem these engines experience. The earlier 5.9 had a few issues like the KDP (Killer Dowel Pin) and there was the # 50 block that had an issue cracking in one place.
I am not sure if the MH's have the same issues.
We are in the early stages of MH Fever that will be treated within the next few months.
38,763 PostsLatest Activity: Dec 25, 2025
