lBumster1
Mar 26, 2014Explorer
Finally solved problem. Replaced ignition relay for the starting problem that would also cause engine to die. Other problem with all the electrical issues was a result of a hot wire rubbing against a screw and wearing off insulation. Had to replace battery disconnect control board located in one of the bays. Have been on a month vacation and travelled over 3000 miles and no problem yet.
38,708 PostsLatest Activity: Mar 05, 2025
