LSVLance
Mar 31, 2016Explorer
I used this harness, it plugged right into the one behind the coin holder.
https://www.etrailer.com/p-3034-P.htmlhttps://www.etrailer.com/p-3034-P.html
I started on the right hand side, got it to pry out a bit then started working on the top, but I was working blind because I didn't know where the tabs were.
If I were to do it again, I'd pry from the right side a bit with a putty knife and then use a screwdriver from the top to slowly start releasing the three tabs across the top. By the time you get the second one released, it gets looser and easier to get the tabs loose. Once the 3 top tabs are released it'll slide right out.
Good luck.
Good luck.
38,763 PostsLatest Activity: Dec 13, 2025
