krivanj
Oct 01, 2017Explorer
The shroud has screws in each corner at the front; if you remove them, you will be able to push the front edge up pretty far, enabling you to see the tops of the batteries and facilitate changing them at some point. Mine has sprayed in foam at the back but it just moves slightly out of the way. Then use a bungee cord to hold it up.
I too, do highly recommend a watering system.
38,706 PostsLatest Activity: Jan 20, 2025
