- RollnhomeExplorer08 Discovery fresh water drain is on passenger side. Can be accessed from 2 basement bays just past slideout. It is a 1/4 turn valve at the back of the bay near the top a 3/4" or 1" line. Red handle
- REV40CExplorerI have a drain for my cold water and hot water in my wet bay.
Dave
2004 Revolution 40C - ValkyriebushExplorer IIOn my 03 Excursion, it's in the second compartment on the passenger side near the water tank. Red handle.
- AvaExplorerOn my 94 Fleetwood Bounder the drain is near my water pump, just a quarter turn valve. Look for such valves near the tank or pump.
- John___AngelaExplorer
sportech wrote:
On my 07 Revolution the drains in the water bay can be opened and then you can turn on the pump. Takes about 10 minutes to empty the tank onto the ground. I have a quick connect for a garden hose so that I can get the water away from the coach.
Dave
Yepir. Go to the wet bay, right hand side lower. Hot and cold low point drains. Open the cold and it will drain the tank as well. If you want it to go quick then just turn the pump on. It'll pump it empty in short order. - sportechExplorerOn my 07 Revolution the drains in the water bay can be opened and then you can turn on the pump. Takes about 10 minutes to empty the tank onto the ground. I have a quick connect for a garden hose so that I can get the water away from the coach.
Dave - zach477ExplorerOn my 08 Fiesta, it's on the passenger side in the storage bay that has my water filter. In the back of the compartment I can see part of the fresh water tank, and the lever for the drain is right there. I didn't know it was there until the first time I tried to fill the tank and succeeded only in getting the ground wet...
There are also low point drains for the hot and cold lines in the utility compartment.
38,774 PostsLatest Activity: Mar 01, 2019
