Theophania_Rex
Feb 21, 2021Explorer
SDcampowneroperator wrote:
Yes, not easy. Since the grey tank is under floor, the lines drain into it from above. Those lines could be rerouted under floor to dump into the tank in its side. Since grey water does not have a solids issue, grading is not a high concern. The u traps under shower likely protrude under the floor so its moot to offset the lines under as well.
You would have to remove the tank, have a side inlet plastic welded into its side, the top fill inlet welded over. Contact a good auto body shop for plastic welding. No glue will work on Poly Ethylene. A rubber flexible coupling to connect pipe to tank will work and allow for vibration and temp changes.
Thanks, this is helpful. Sounds a little too complicated, time consuming and maybe costly. I want to get on the road, like now!
Maybe it would simpler if I left where the pipes enter the floor in the same places, but just rerouted the rest of the piping around the front part of the room? I'd still have piping sticking up over the floor, but at least it would be less in the way and I wouldn't have to build an entire floor on top of everything. And less of a risk of having to to cut through anything under the floor (framing, joists) to get the pipes routed. Still a trip hazard, though, but a lot less work.
38,707 PostsLatest Activity: Feb 18, 2025
