RJ_2003_Traditi
Feb 27, 2014Explorer
Now that the heater appears to be running normally, make sure your outside shower (sprayer) in the water bay has both valves turned off. If both of these valves are opened, you will never know it and you will have the exact symptoms you're describing. With both valves opened, cold water will mix with the hot and produce lukewarm water at all faucets.
38,782 PostsLatest Activity: Aug 11, 2021
