Texas wrote:=
Have you had ride height set to factory spec?
Do you have one or two ride height valve in front?
Same question, rear axle?
Thanks for the help Texas.
Ride height was set to factory.
One ride height valve in the front, two ride height valves in the rear.
I installed a switch on the dash that when flipped on locked the air in all the air bags. I road tested the coach again and at 15MPH flipped it on. I did the same sweeping right turn with the immediate left turn at 20MPH. This time the coach was much more stable with very little sway in the right and left turn. I also noticed the it steered better on the highway and in town.
