Woodsie8_
Sep 13, 2020Explorer
ndrorder wrote:
Unless you have an inverter which uses 12v battery to make 120V plug power, the two are separate and having something plugged in will not affect the battery. If you do Have an inverter, the plugs would stay powered when shore power and the generator off. Doesn't sound like that is the case.
If only using lights and water pump, those shouldn't drain a battery that much that 3 to 4 hours of generator can't replenish.
I think I have an inverter.
38,707 PostsLatest Activity: Feb 18, 2025
