427435 wrote:
flyinlow1000 wrote:
Ok..I got it backward. The Vision I'm looking at has aGVWR of 15500 lbs and a GCWR of 26000 lbs.
Well, I'm going to have to disagree with many of you. IF the numbers above are accurate, AND IF the hitch (and maybe the frame) are upgraded, AND IF the MH only weighs 15,500 when fully loaded, you should be able to pull 10,500 lbs. That's what the manufacturer said it would with his ratings.
Those are the GVWR (I got off the sticker) and the GCWR (I got off a Ford site). It said ALL F53 frames ahve a GCWR of 26000lbs.. I agree as the size of the coach goes up the GVWR goes up and the trailer capacity goes down. A pusher is out of the question due to limited parking space at race tracks and a 4 wheel down tow is out of the question due to the is a race care trailer..
